HELP WITH OC reboot
BliZzZarD
Ok I have a ASUS A7N8X Deluxe with a 2500+ barton... Trying to over clock it
I put the settings at 11x200;1.675 Vc....
I have left the memory alone.. I have crusail 3200 ddr 400.
I boot no problem.. reads at 3200+
I also have a 9800np flashed to pro running at 380/340 so I'm not overclocking!
Ok but now when I run 3dmark3... My video card reads some sick numbers... and then the system reboots...
I have the ASUS utility install and with noload its reading 102F... I have a Vantec HSF...
What am I doing wrong
what's the memory brand of your 9800np card?
I've seen problems with Infineon mem on 9800np coz basically your "new" BIOS(9800Pro) changes voltages and CASs of that mem and Samsung seems the only one to cope with that.
Try underclocking your videocard memory and bench just for trial sake :s
good luck!
3.3ns should run @(1000/3.3=303.03)MHz :s 340Mhz is too much for them! try underclocking till 303 speeds
Edit: you are overclocking since 340MHZ if for 2.8ns memory 😛
Didn't work! I am going to reinstall Windows... And have a clean install!
Should I do anything with the memory settings?
