The following was taken from Planet Hardware's site regarding overclocking Geforce Cards:
"First, if you don't see the overclocking options tab from within the 'additional properties' area of the driver properties window, you'll need to enable them. Bring down the Start menu, choose Run, and type in 'regedit'. Now, navigate over to the following directory (or 'key') HKEY_LOCAL_MACHINE\Software\NVIDIA Corporation\Global\NVTweak. Create a new DWORD value, named CoolBits and set its value for '3'. Now when you open up the 'additional properties' area of the drivers, you will see the overclocking tab. "
Question: How do you do the 2nd to last sentence..."Create a new DWORD Value, named Coobits and set its value for 3"
thanks
Mattlock (newbie)
thanks
Mattlock (newbie)
