Help!!! with nvdia nforce4 LAN
doncerdo
Hi! I purchased a Netgear Wireless Router Model WGR614v5 and noticed that when I plugged it in my A8N-SLI Deluxe Motherboard's nVidia ethernet controller it could not aquire an IP. I later used the other ethernet port from the motherboard, a Marvell Yukon Gigabit chip and it worked flawlessly. So, I went back to the nVidia ethernet port and found out that ONLY if I disable the nVidia hardware firewall will the connection aquire an IP address from the router. Is there any way to configure the nvidia firewall and/or the router so that the connection works?? In advanced, thank you very much for your time.
