Help with Norton Ghost
EMAN
Banned
Jan 28, 2000
1,359
I'm using version 6.1 and I can't seem to get it working.
I'm trying to make a disk image.
I read the manual and it's no help.
I get this error.
!dump file on drive being dumped
I guess I have to click a image file but what???
EMAN
Banned
Jan 28, 2000
1,359
Ghost displays this message when the location you selected for saving the image file is on the same physical disk that you selected to be imaged. This normally happens when you have only one physical drive on the computer. In this situation, you are attempting to save the contents of the drive on the drive itself. Ghost cannot create an image of a drive and then save the image file on the drive being imaged.
To save an image of a computer's physical disk, the computer must have a second physical disk or other suitable media for saving the image file, such as a Jaz disk, Zip disk, or access to a drive on another computer. Image files can also be saved to CD-ROM, but only by saving them elsewhere first, then moving the files to the CD-ROM.
If you have a single hard drive with multiple partitions, you can create a partition image instead of a disk image and save it on another partition on the same physical hard drive.
Never mind I found it from their site.
