help with new TV and QAM tuner
Homerboy
30,890
5,001
I just received my new TV for the bedroom: http://www.newegg.com/Product/Product.asp?Item=N82E16889025002
Everything is perfectly fine, but I can not seem to get the NTSC/QAM tuner to work.
I have the cable from my wall going directly to the cable in (there's cable in and antennae inputs) I can watch basic cable fine on it, but I can only input channels 1-99
and TimeWarner broadcast the unscrambled HD channels in my area in 500+:
http://www.timewarnercable.com/Customer...&Image1.x=24&Image1.y=10&Image1=submit
Any input would be GREATLY appreciated. Maybe I do in fact need a cable box inbetween wall jack and TV to get to the higher numbers?
HELP!
Shawn
32,236
53
QAM doesn't use your cable company's channel numbers. For example, with my local comcast NBC is 85.1, ABC is 85.2, Government Channel is 86.1, FSU Channel is 86.2, PBS is 86.3, PBS Kids is 86.4, CBS is 86.5, and FOX is 87.1.
JasonE4
1,363
There's no way to either scan or display just the digital channels? What are the options for channel scanning using the cable in?
RossMAN
Grand Nagus
Feb 24, 2000
79,035
441
Originally posted by: Homerboy
well thats a start... but how do I tune those suckers in then?
1) Go to AntennaWeb.org enter your physical address and it should show the digital channel.
2) On your TV enter the channels using the number pad.
Shawn
32,236
53
That's incorrect. The channel numbers for OTA are different than the QAM channels.
RossMAN
Grand Nagus
Feb 24, 2000
79,035
441
LOL you're right, thanks :)
Homerboy
30,890
5,001
yeah I cant just enter the number (per my OP)
anyways, buried DEEP DEEP in the menus is "DTV - autoscan"
VIOLA!
Staples
4,953
119
I use an antenna to get the OTA signals but on the TV in the other room, I just auto program and I pick up the unencypted QAM channels that TWC puts out. Something I noticed though is that the signal strength is only about 40% so once in a while I see a drop or two because the tuner is not that sensitive.
RossMAN
Grand Nagus
Feb 24, 2000
79,035
441
VIOLA!
:thumbsup:
Homerboy
30,890
5,001
VIOLA!
:thumbsup:
I have to say I'm not overly impressed
in the past 24hrs I've seen 3 things actually broadcast in 720 or better... everything else is 480 STV and looks like sh!t
alrocky
1,771
Maybe I do in fact need a cable box inbetween wall jack and TV to get to the higher numbers?HELP!
Do you have tried the cable box? Have you called TW and asked if you need a digital cable box?
Shawn
32,236
53
VIOLA!
:thumbsup:
You have to watch during primetime. During the day and late at night there isn't much in HD.
Homerboy
30,890
5,001
Yeah lotsa sports Sunday and then at night Grammys etc in 1080i
very nice... hard to switch back to STV then :(
