I am building a new system with the purpose of mostly (say 3/4) office/ programming/ multimedia applications and also 1/4 of the time I will probably game.
I will keep my current 19'' monitor and add another 22" along side it for a dual setup with gaming done only on the 22".
Budget wise, I dunno...I just wanted something that's currently considered a good bang for the buck and will last about 3 years (with maybe, MAYBE, little tweaks (ie: upgrades and/or overclocking) after 1.5-2 years. OS will probably be Vista 64.
Based on the notes above, here's what I came up with so far:
Processor: Q6600
Memory: 2x2GB DDR2-1000 (probably g.skill)
Video: 8800GTS-512 (probably EVGA)
Mobo: ??? (needs: stable, fairly overclockable, good onboard sound)
Case: ??? (needs: silent, includes power supply)
HDD: ??? (needs: silent)
Are my choices good so far? If not, what else do you recommend? Also, what do you recommend for the ones that I had no idea for?
Thank you.
EDIT
On a second thought, I'll be getting a ps3 for gaming purposes so only need the computer for the rest. So the 8800GTS drops in favour of the HD3450 or HD3650 (10.1 directx, silent, cheap). Would this be a fair video card choice?
EDIT
Processor: Q6600
Thank you.
EDIT
EDIT
