- Apr 28, 2019
- 6
- 0
- 11
PLEASE when you POST threads asking for input on system builds tell us...
1. What YOUR PC will be used for. That means what types of tasks you'll be performing. Mainly nox android emu. Games at 1080p, on occasion.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread 5-600
3. What country YOU will be buying YOUR parts from. USA
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU. In the USA
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc. No pref, have always used nvidia gpu, and amd CPU tho
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are. I have some parts. Case, ssd, ps, mouse, kb, monitor.
7. IF YOU plan on overclocking or run the system at default speeds. Default, can overclock
8. What resolution, not monitor size, will you be using? 1080p
9. WHEN do you plan to build it?
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it. Asap.... within a week
10. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software? No
