1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
gaming - Counter Strike and surfing net
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
~$1500
3. What country YOU will be buying YOUR parts from.
USA
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU.
n/a
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
Intel i5 n nVidia
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
complete new build
7. IF YOU plan on overclocking or run the system at default speeds.
Just want stock speed as I do not know how to overclock nor do I want to deal with instability. I want something fast but VERY stable.
8. What resolution, not monitor size, will you be using?
....Max?
9. WHEN do you plan to build it?
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it.
Within next week or so.
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
Windows 8.1 or 7
Ok, I havent built a maching in about 7 or 8 years so I'm sure things have changed since then. I am currently using a Sony laptop to play CounterStrike and would like to build a new machine. Plus, I need a new PC anyways.
Im looking for i5 4670, GTX 770, 1 SSD for boot drive, and 1 10k RPM HDD for storage. Everything else is up in the air as far as brand range of performance goes. I want to stay close to budget. No need for overclocking. As I stated before, I want stability. Oh, I also want the PC to be as silent as possible. e.g. Case, Fans, etc... Not sure if ATX or MicroATX is the way to go. I would rather have something not so bulky!
Thanks!
~$1500
USA
n/a
Intel i5 n nVidia
complete new build
....Max?
Windows 8.1 or 7
Thanks!
