Help with my x99 gaming rig
drcc
Hello friends, m planning to built water cooled x99 gaming rig. Its my first water cooled build. Till now i've researched and finalised products as follows but every thing is biased. Not finalised list, waiting for ur review and response
1 mobo x99 asus rampage 5 extreme or msi godlike gaming.
2 processor intel 5930k
3 case corsair 900d or nzxt 840
4 graphics card asus 980 ti reference
5 ram ddr 4 avexir 16 gb kit
6 psu corsair hx series 1000 watts
7 hdd plextor 250 gb pcie ssd for os
2 segate barcuda 2 gb in raid 1 for backup
For water cooling
1 ek fc titan x nikel-acetel water block for gpu
2 for cpu ek supremacy evo clear csq or xspc raystorm or swiftech apogee
3 ek d5 pmw pump with clear top
Both these i'm planning to import from uk through my friend
Products below this m planning to buy from aliexpress .. but as per ur suggestions i can also buy them and ship from us or uk.
4 xspc ram blocks
5 not decided till on mobo water cooling
6 2 480 radiators xspc or syscooling
7 xspc hardline compression fitting 10*14 mm triple seal.
8 barrows 250 or 300 mm reservoir
9 xspc hardline petg tubing 5 tubes 400 mm each.
10 noctua nf12 or corsair sp120 fans
Planning to buy bitspower crystal link and some dual triple rotary fittings from performance pcs
That's it for now friends please help me to plan and build this rig,.,. Thanx.
i am assuming this is gonna be a dual loop system?
Because you already have too many surplus parts for a dual loop, and overkill surplus parts for a single loop.
Also i would not trust aliexpress..... there is just so many things wrong with that place.
I think the numbers are just their place in the list, not the quantity.
I wouldn't bother with the ram cooling, it really won't do much. Depending where you are you might just be better off buying local. I've gotten some Barrow fittings and whatnot from Aliexpress, and while they were a little cheaper it wasn't worth waiting a month to get them.
For your first build, I'd stay away from rigid tubing. Unless you're much more meticulous than I am, you'll end up fiddling and repositioning things a lot, which is enough of a pain with standard tubing.
