help with my usb scanner.....umax3400
Koing
Elite Member <br> Super Moderator<br> Health and F
Oct 11, 2000
16,843
my problem is that when I try to scan now I get this annoying error
PSP caused an invalid page fault in
module KERNEL32.DLL at 0167:bff87f00.
Registers:
EAX=c00309c4 CS=0167 EIP=bff87f00 EFLGS=00010202
EBX=053bff88 SS=016f ESP=052c0000 EBP=052c0080
ECX=817799a8 DS=016f ESI=817895c4 FS=3ac7
EDX=bff76855 ES=016f EDI=052c0098 GS=0000
Bytes at CS:EIP:
ff 75 10 6a 01 e8 ca 07 00 00 85 c0 74 08 ff 75
Stack dump:
052c0098 052c00b4 052c025c 817895c4 053bff88 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
it closes the twain drivers that come up...and nothing else.....when I try to load it in again......nothing happens......then when I go to aquire again it tries to look for the scanner but nothing happens..it just gives me this error message that the link between the scanner couldn't be found...this also happens in photoshop..
any same types of problems? or any help?
I am running Win98se.....I got a usb microsoft optical mouse and that works fine......
Koing
cloudchief
531
This may or may not help you. My sister-in-law had a usb Umax scanner she could not get to work. When I visted her I disabled everything that was running in the background and reinstalled the scanner, it then worked, I eventually figured out what it was that was running in the backround that messed up the scanner, but now I do not remember the program. Anyways you could try what I did.
Koing
Oct 11, 2000
16,843
ok thanks i'll try that sometime:)
Koing
