Hi,
I recently buit a desktop with helps from some good fellows here at anandtech
However i am running everything on the default settings and want to know if there are places i can improve. Following is my configuration. I know i could have got better versions for some components, but being a student i had to stiff budget to work at
AMD Athlon XP 2500+ Barton - Retail
Asus A7N8X Deluxe
512 PC2100 DDR
SAPPHIRE ATI RADEON 9000, 64MB DDR
80GB WD + 80GB Maxtor
MicroAdvantes CD-RW
Please suggest some modifications so that i can run it optimally without much risk or frying the CPU.
TIA
btw, what does a "rig" stand for
Asus A7N8X Deluxe
512 PC2100 DDR
MicroAdvantes CD-RW
TIA
