help with my msi gf2mx
SeVeRaNCE
65
i recently got a MSI starforce gf2 MX 64mb. and im not sure why i look in the MSI clock section. and the memory clock is set to 334mhz. which is false because if it was true i dont think i would be running games and such. even if i set it on default and reboot it goes back. anyone know what causes this? all iv done is installed det 11.01 drivers, and in bios set agp aperature size to 128. im not sure if those have anything to do with it or not just trying to give all the stuff iv done.
DeeK
700
It sounds like your MX uses DDR memory. DDR memory has an effective clock rate of twice the actual clock rate. The standard memory speed of an MX is 166MHz, which has an effective clock of 333MHz. Your settings show the effective clock rate, so 334MHz is about right.
