Hello everyone.
Well, the OverClocking bug has bitten me and I decided to "mildly" OC my rig in that, 1.) So many of us have been achieving relatively easy OC's with the C2D, and 2.) I realized that with the parts I've selected, there's a lot of headroom to go from "stock" performance.
Anyway, I'm now running my C2D E6600 at 2.99 GHz, V Core is set at 1.30, FSB at 333. Memory manually timed at 4-4-4-12 with voltage set to 2.2 (recommended settings per Crucial for my Ballistix set). Still using stock, Intel cooler with idle CPU temp avg'ing 34 degrees. Like I said, a pretty mild overclock. On to my questions:
- System is stable and solid, but, when restarting, it powers all the way down, waits for a about 3 seconds, then begins to power up. The fans stop spinning completely, where as before during a restart, they system never really powered down...it just re-booted. Once started, XP boots up with no problems. Is this normal?
- In setting my memory's timings manually, I noticed a "DRAM Write RecoveryTime" setting. I left this at the default 4 Clocks value. What does this setting mean and what should it be?
- Last, again in reguards to memory, when does OC'ing memory become mandatory, ie. even though I've only bumped my CPU/FSB settings by a little bit, do I now need to look into increasing memory performance?
I'm really not looking into pushing my rig by much. More concerned with making sure I'm not damaging any components or running any settings that lead to instability or performance issues.
Thanks for any help or suggestions...
Twitch
Twitch
