stuckinasquare3
Liquid/water cooling was always one of the things that I thought was always too scary for me to attempt. Recently though, I thought it might be a fun project to try out and a good way to boost the performance of some of my aging components. There are so many different options though, how does one even know where to begin? Open loops, closed loops, all in ones, etc.
I suppose the first thing I should do is outline my goals:
1) not spend a lot of money
2) not buy a new case
3) water cool a cpu and gpu with the option of adding a second gpu in sli
Currently I have a thermaltake level 10gt that I love and want to keep forever. It has all 4 5.25 in bay's available for water cooling use. Inside that case I have an x58 motherboard with an i7 920 and a 670gtx.
I've ruled out options such as the corsair hydro series because they only cool the cpu and can't be expanded to cool the gpu. At this point I was looking into the kit options and also building a custom setup but I can't seem to figure out the most cost effective way to get all the things I need.
Here are the things I think I will need based in my research:
1 pump, maybe the mcp655-b
1 bay reservoir (here's a link to both in a combo http://www.frozencpu.com/products/1...55_w_Blue_LED_Light_-_Clear_Silver_Black.html)
1 240mm radiator for the top of my case (?)
1 120mm radiator for the front or rear of my case
Some tubes
Cpu water block
Gpu water blocks
Some questions:
Am I missing anything?
Is the pump strong enough to push through all these things?
I've heard there's something called a "pump top". Is that something I need?
Do I have enough radiators?
How much should I expect to pay for all this?
Thanks!
Some tubes
Cpu water block
Gpu water blocks
Some questions:
Thanks!
