Help with my custom build:
bluedeviltron
223
_____________________________________________________________________________________
Motherboard:
MSI K8N Neo4 Platinum Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16813130484
$142
CPU:
AMD Athlon 64 3200+ Venice Integrated into Chip FSB 512KB L2 Cache Socket 939 Processor - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16819103535
$203
Case:
Antec Solution SLK3000-B Black Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16811129152
$50
PSU:
XCLIO XClio 450BL ATX 450W Power Supply 230Vac - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16817189003
$52.50
Memory:
CORSAIR ValueSelect 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Kit System Memory - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16820145440
$77
Video Card:
BFG GeForce 6600 GT Overclocked 128MB PCI-Express Video Card
http://shop2.outpost.com/product/4310625?site=sr:SEARCH:MAIN_RSLT_PG
$199
Hard Drive:
Seagate Barracuda 7200.7 ST3200822AS 200GB 7200 RPM 8MB Cache Serial ATA150 Hard Drive - OEM
http://www.newegg.com/Product/Product.asp?Item=N82E16822148033
$122
DVD Drive:
NEC Black 16X DVD+R 8X DVD+RW 4X DVD+R DL 16X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM 2M Cache IDE DVD Burner - OEM
http://www.newegg.com/Product/Product.asp?Item=N82E16827152035
$49
*edited*
A couple of things. I haven't really heard the name Foxconn before, but every review on newegg for that board is positive, and it has all the features I need.
Would you recommend going with the Venice or Winchester core for the CPU? And is it worth another $80 to get a 3500+ Venice?
I know I've been told to stay away from cases with power supplies included, but every review for this case is positive, and it's on sale this weekend. Do you think I should stick with this because I don't think I'm going to be doing a lot of PSU heavy things like overclocking, etc...
Does Serial ATA150 mean it's a SATA hard drive? Are those the fastest?
Does everything check out? Is it all compatible? Any other suggestions?
bluedeviltron
223
And also, if this system is OK, what other equipment do I need to buy before building it? Do I need any extra cables, cooling supplies, anti-static bracelets, etc...?
t3h l337 n3wb
2,698
Bluedeviltron, you've already posted like 8716293 threads on this system. Anyways, the Foxconn is so-so, but if you're overclocking, you want a DFI Lanparty. If you're not, go with the MSI Neo-4 Platinum for it's great features. That PSU is CRAP. Get a good brand name PSU, like Antec, Fortron, Sparkle, XClio, OCZ, or many of the others listed on the forums. Stick with the 3200+ Venice; the 3500+ isnt worth it. Oh, and drop the OMFG-Expensive-as-hell DVD burner. You won't need Lightscribe. Just get a good ~$50 burner, and you'll be set.
bob4432
11,727
46
using the foxconn motherboard will probably limit your o/c ability. they make nice boards but they are more oem style, without the voltage / fsb adj you would need tp do some seriouos o/c that venice. you may wan to d/l the manual first to verify this, but my current setup is using a foxconn m/b, and although as reliable as you could ask for, i can't get my 2.8c very high without prime errors, actually thinking of chainging boards because of this. maybe look into a msi, asus, abit or gigabyte m/b. the dfi lanparty are serious o/c boards, but they are extremely finicky about ram, have read a lot of bad issues with them.
also, stay away from the rosewill p/s, get an antec that fits your needs.
bluedeviltron
223
Is it really necessary to overclock? I mean, how much faster could I get the system to go? Isn't it already fast enough for video editing and gaming?
bluedeviltron
223
bluedeviltron
223
OK, I don't think I'm going to be doing a lot of overclocking. Is that the only drawback to the Foxconn board?
theMan
4,386
well, you could get a fx-59 out of a 200 dollar chip, so yes, it is worth it. also, get the msi k8n neo4 plat. and a psu like the seasonic s12-430. also, get an NEC nd3520a dvd burner, because it kicks @ss
bluedeviltron
223
I read in the reviews for the k8n neo4 plat that someone had a hard time installing their 6600 GT because it blocked the water block or something. Is that a big problem?
prosser13
103
Post one post at a time! Get the NEC ND3520-A and if your building a gaming rig which can overclock quite well get the AX8 and a better graphics card. Get a SATA hard drive, the SATA version of the one you picked will do. The Tagan TG480-U01 is good value, and they also do 530W and 580W versions. Also, get a decent case, and that second power supply is too cheap. In fact, rather than getting a AX8 and better graphics card, spend the extra money on a better case. You want a better case otherwise you will have to upgrade because of poor airflow.
t3h l337 n3wb
2,698
Alright, now THIS is looking like a good system. The parts you listed right now will give you a nice, moderate overclock, and a lot of great features as well. The Neo-4 Platinum isn't he BEST board for overclocking (the DFI Lanparty is a bit better), but it has a lot more features, and will still give you a great overclock. And you won't have to worry about water blocks, because I doubt that you're going to be water cooling your system. I'm a big fan of that XClio PSU. It's really cheap, has 12V rails, and it's made by a great reputable manufacturer.
bob4432
11,727
46
what about getting a $100 antec case that has a p/s already? maybe something like the 835 series. they come with a good p/s too. you don't need a 530/580W p/s(look at my sig), for your build you need a good quality 350-400W, even to o/c. you also might want to look into a hitach sataII hdd instead of the one you picked, or they have a 80GB one that is only ~$65, and i have read reviews that say it is the sweet spot for price/performance.
also that board is really nice, a friend of mine just got the sli one to replace a dfi sli board, just had a lot of problems with 3 of the dfi sli boards. although the msi doesn't have all the hardcore o/c availability of the dfi, they usually make an extremely good enthusiast board.
bluedeviltron
223
Sounds good. So do you think I should go ahead and order these parts? Like I said, I'm not going to be doing a whole hell of a lot of overclocking (I might once I figure out what it is). So it seems like a pretty good setup.
Now what else am I going to have to buy to build the complete system? Other cooling stuff, antistatic, cables, etc...?
shoRunner
2,629
thats a good case...but you would probably want to get another 120mm fan (the case only comes with one) to have a good intake-->exhaust fan setup.
snomunki
21
Recommendations:
MSI/Gigabyte/ASUS Mobo.... DFI is over-rated.
Enermax/OCZ PSU... only ones I will EVER use.
NEC 3500 series DVD Burner.... DL is going the way of the dodo... just get good DVD-+R speeds...
bob4432
11,727
46
Originally posted by: snomunki
Recommendations:
no antec p/s?
bob4432
11,727
46
looks good to me, i would build it if it were my time to build another, but the only change would be a antec835 series or 1080 series case and the evga video card i recommended. nice to save ~$60 :)
bluedeviltron
223
So what makes those cases better than the one I listed? Are they a lot more expensive?
And I already bought the 6600 GT at Frys for $200, I'd rather not take it back.
bob4432
11,727
46
no it has nothing to do with expense, i am a cheap bastard, and to be honest, i thought it was a different case, a smaller one. that case will do excellent :) i understand about the card, but frys does have a pretty relaxed return policy, but that is a good card, just a little on the high side, that is all.
bluedeviltron
223
Cool, I'll think about it. I'm not sure if I should take it back and get the Radeon x800 XL though, for $100 more.
