help with my cpu patch
tato27
i need to know if my patch is good or bad for get oc 4GHZ
my cpu is amd 965 125W my model is hdz965fbk4dgm
my patch is caca ac 0945fpmw
my mb is msi 770 g-45 i never get any cpu oc even phenomII 550 3.7 oc no more /athlon II 240 3.7 no more
but with my new 965 i can get 3.8 stabel so i need 2 know if my cpu patch is good or bad or ther r any list for good cpu patch ?
cuz long time i was see some review about good patch but i forget it now
Hi Tato, I take it you're not a native English speaker so you may want to check your translation. A "CPU patch" doesn't make sense in the context you're describing. Perhaps you mean a "stepping code"?
stepping code / batch /patch whatever what is wrong in oc is it my MB or my CPU ?
is 770 not good for oc cpu like 965 in oc to get 4 GHZ like i say i never get any cpu go over 3.7 GHZ but all the cpu was low clock phenom II 550 was 3.1 go to 3.7 and athlon II 2.8 go 3.7 to my 965 best oc was 3.8 in vol 1.44 and temp with priem95 53C in load
do i need MB like 890 or 790 or cpu isnt good for oc
You're talking about the bulldozer patch, that patch doesn't work with Phenom II.
MSI G45 is a crap, it's a bad motherboard for overclocking. Zero cooling on the vrms so if you run at 1.45v for a few years it'll probably die on you. Don't buy an 890 chipset, it's not worth your money. When your computer dies buy an intel.
