Help With My Build
My computer has become quite out of date, and I've decided it's time to build a new one. It will be used for gaming and other conventional media purposes. I'll be purchasing the parts through newegg, and here's what i've come up with:
AMD Athlon 3500+ $267
Gigabyte GA-K8n Ultra-9 Motherboard $140
eVGA Geforce 6800GT PCI-E $379
Antec Aluminum ATX mid Tower Case $130
1 GB Corsair ValueSelect Ram $75
Nec DVD Burner $50
Asus DVD-Rom $29
Seagate Barracuda 160GB SATA Hard Drive $112
Antec 550W True Control PS $90
I don't plan on overclocking. I am on a budget, of around $1500. Any recommendations, or comments are welcomed and greatly appreciated.
Also, what's a good 17" CRT monitor?
You could get a 200GB IDE HD for $97.00
I don't like tha case. It's ugly (personal choice)
$267 for a CPU is a lot of money.
The real world difference between a $267 CPU and a $150 CPU is very very tiny.
I want a Serial ATA HD. I don't want an extremely flashy case, just something that is good quality, has enough room, and good cooling... This case was one of the only ones that I actually liked the look of. The cpu is the one thing that I am probably set on.. at the 3500+ spot is where the price seems to jump out of my budget, so I figured i'd get the best I could.
Dont get the 3500 its not really that much better then a 3200 but costs 70 bucks more
also maybe get this power supply it will be good enough to run what ever you want you
really dont need a antec true power
also i linked a nice cheaper case not too flashy 🙂
and lastly if your not going to OC just get a chaintech mobo cheap too 😛
Antec Solution SLK3000-B Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.asp?Item=N82E16811129152 50.00
ENERMAX Whisper II EG465P-VE FMA(24) ATX12V 460W Power Supply - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16817103464 76.00
AMD Athlon 64 3200+ Winchester Integrated into Chip FSB Socket 939
http://www.newegg.com/Product/Product.asp?Item=N82E16819103502 190.00
CHAINTECH VNF4/Ultra Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard
http://www.newegg.com/Product/Product.asp?Item=N82E16813152049 93.00
CORSAIR ValueSelect 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200)
http://www.newegg.com/Product/Product.asp?Item=N82E16820145440 74.99
Seagate Barracuda 7200.7 SATA NCQ ST380017AS 3.5" 80 gbSerial ATA150 Hard Drive
http://www.newegg.com/Product/Product.asp?Item=N82E16822148040 63.00
NEC ND-3520A Black IDE DVD Burner - OEM
http://www.newegg.com/Product/Product.asp?Item=N82E16827152035 47.99
eVGA 256-P2-N376-AX Geforce 6800GT 256MB GDDR3 PCI-Express x16 Video Card
http://www.newegg.com/Product/Product.asp?Item=N82E16814130215 369.00
TOTAL 963.98
case=good,mobo=bad, go for an msi, you can't go wrong with them,and get a venice or san diego 3500 they are on the new 90m soi process and are good for ocing
I also suggest teh MSI Neo4. The Chaintech VNF$ Ultra is a good budget board if you are looking to save money.
You should definitely go with the Venice/SD core CPU. They support SSE3 instructions, and are supposed to OC better than the Winchesters, and much better than the 130nm Newcastles.
If you don't understand what SSE3 instructions means, just know that it is better. 🙂
