help with my asus a7v133
needshelp1234
12
i have an asus a7v133 motherboard. when i try to install the 4 in one driver under windows me, it locks up my comp after hitting 100%. Am a installing it incorrectly. i've been running the setup.exe file. thank you
Boonesmi
14,448
what version of the 4in1? also maybe you want to try to uninstall all the 4in1 drivers first.
also... are there any conficts in device manager?
needshelp1234
12
the latest ones, the 4.28 one. Not aware that i can unistall previous 4 in one drivers. do they appear on the add remove program section in the control panel ? I have no conflicts with my hardware according to windows me. although my usb device, nic card, sound card and some steering device all share irq 5. unfortunately when i run my sound card and nic card at the same time ( transfering files between computers and playing a music) my comp crashes . winme sucks !
Boonesmi
14,448
you might want to try the latest 4in1's if i remember right they have some fixes for winME version 4.32 you can get them at via's web page www.via.com.tw or www.viahardware.com
and... when you double click the the "setup.ext" (for the 4in1) you can select "uninstall"
