Help with my array please?
TruePaige
Hey guys, I was creating an array in PHP through pulling values from two tables where the id matches and sadly I get an error.
$result = mysql_query("SELECT s1.pfiles
FROM pfiles s1, puploads s2
where s1.id = s2.id and
s2.tags = $search");
$row = mysql_fetch_array($result);
$tagdata = $row;
print_r($tagdata);
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in W:\www\fs\layout\test\tpl_tagcloud.php on line 128
If any of you could help I'd appreciate it. =)
Originally posted by: trexpesto
curious - can you print $result ?
It doesn't throw an error, but it doesn't display anything.
In case your curious, I am connected properly
$search=$_GET['search'];
htmlspecialchars(stripslashes($search));
mysql_connect('lREMOVED', 'REMOVED', 'REMOVED');
mysql_select_db('fileupload');
Originally posted by: troytime
it means your query is returning 0
if(!mysql_num_rows($result))
echo "no rows returned";
Huh..I wonder why that's happening...any things that would cause that? I reference these rows throughout the program and it works...hmm
try wrapping your query around ' and concatenate the PHP variable
Code:
$query = "SELET * FROM this WHERE something='".$search."';"; //i ended the query string in ";" and also ended the PHP statement with ";"
If search is from user input, make sure it's escaped properly!
also, I would set it up like this for better error handing:
edit: attach code sucks!
$query = "SELECT s1.pfiles
s2.tags='".$search."';";
$result_set = mysql_query($query) or die('error: '+mysql_error());
if(mysql_num_rows > 0) {
while($row = mysql_fetch_array($result_set) {
//do something per row - assuming multiple rows returned
} else {
echo 'No Rows Returned';
