Right now im getting hit with NANs and UNSTABLE_MACHINE on both cards. I already deleted the work/que/WU folders and re-started the client, and it maybe folds 1 WU but then both cards end up doing the same thing. Cant even fold right now...uhhhggg
[18:33:10] + Working ...
[18:33:10] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -nocpulock -checkpoint 15 -verbose -lifeline 4728 -version 623'
[18:33:10]
[18:33:10] *------------------------------*
[18:33:10] Folding@Home GPU Core - Beta
[18:33:10] Version 1.19 (Mon Nov 3 09:34:13 PST 2008)
[18:33:10]
[18:33:10] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[18:33:10] Build host: amoeba
[18:33:10] Board Type: Nvidia
[18:33:10] Core :
[18:33:10] Preparing to commence simulation
[18:33:10] - Looking at optimizations...
[18:33:10] - Created dyn
[18:33:10] - Files status OK
[18:33:10] - Expanded 46646 -> 252912 (decompressed 542.1 percent)
[18:33:10] Called DecompressByteArray: compressed_data_size=46646 data_size=252912, decompressed_data_size=252912 diff=0
[18:33:10] - Digital signature verified
[18:33:10]
[18:33:10] Project: 5768 (Run 7, Clone 198, Gen 316)
[18:33:10]
[18:33:10] Assembly optimizations on if available.
[18:33:10] Entering M.D.
[18:33:16] Working on Protein
[18:33:17] Client config found, loading data.
[18:33:17] mdrun_gpu returned
[18:33:17] NANs detected on GPU
[18:33:17]
[18:33:17] Folding@home Core Shutdown: UNSTABLE_MACHINE
[18:33:20] CoreStatus = 7A (122)
[18:33:20] Sending work to server
[18:33:20] Project: 5768 (Run 7, Clone 198, Gen 316)
[18:33:20] - Read packet limit of 540015616... Set to 524286976.
[18:33:20] - Error: Could not get length of results file work/wuresults_03.dat
[18:33:20] - Error: Could not read unit 03 file. Removing from queue.
[18:33:20] EUE limit exceeded. Pausing 24 hours.
does that on every WU on each card^
