oldtrout
I have used this program for some time and it worked flawlessly but lately I have run into problems.
I even deleted the program and did a reinstall.
After I add files and do a track analysis I do a track gain.
When it goes to do the gain on most of the tunes I get a dialog box "Can not open or modify - change file log"
Then if I keep canceling the dialogue box the change is made and I have to do the same thing for most of the files.
When you are doing a large number of files this is a bummer.
Suggestion please?
Thanks
Suggestion please?
Thanks
