Most plasmas have a 480Hz or 600Hz sub-field drive while some Pioneer plasmas offered an 840Hz sub-field drive. They don't have motion blur due to them using phosphors like a CRT does. The liquid crystal in a LCD can't physically switch fast enough and creates motion blur.
its called ghosting, motion blur is an entirely different thing.
http://en.wikipedia.org/wiki/Motion_blur
http://en.wikipedia.org/wiki/Ghosting
Likewise refresh rate is something that only exists in CRT:
http://en.wikipedia.org/wiki/Refresh_rate
While what LCD suffer from is response time (CRTs have a response time, its just much better than an LCD):
http://en.wikipedia.org/wiki/Response_time_(technology) EX: the op bought an LCD with advertised 2ms response time
Both technologies use a frame rate:
http://en.wikipedia.org/wiki/Frame_rate EX: Most displays get 60Hz frame rate (60 cycles/second, aka, 60FPS)
What is a "sub-field drive"?
The thing is, LCD is a CONSTANT light source which changes color, CRTs need constant refreshing.
You can see the color alteration of the constantly on LCD (which has no flicker or refresh rate), and you can see the refreshing and the resulting flicker of the CRT... Or at least, I can see all that, I can also see the screen gate effect of any LCD I ever used.
All that being said, I still think LCDs are vastly superior to CRTs... CRTs have tearing just like LCD do, CRT has flicker and refresh issues which LCDs do not, CRTs have wobble which LCDs do not, CRTs have uneven "pixels" and screen shape, always! (you had to manually align the screen to make it as square as possible and as non deformed pixels as possible, but it was never perfect and always bothered me)... CRTs are loud (require fan), need degaussing, run hot and are power hogs...
CRTs do have the big advantage of not having a native resolution... the non native resolutions in LCDs look terrible...
So all in all, I much prefer LCDs to CRTs with all their flaws... so does the vast majority of the population...
Plasma? Plasma's greatest problem is that it violates your wallet. that and burn in... and I am sure some other issues... but mostly its money.
There is, however, such a thing as a perfect display... its called OLED
http://en.wikipedia.org/wiki/OLED
