Looking at picking up the Antec Super Lanboy for my Gigabyte mobo
The specs on the lanboy says the mobo can be 12"(W)x9.6"(L) The mobo is 30.5cm x 24.4cm.
If I'm converting them both to mm correctly then
Case 304.8 x 243.8
Mobo 305 x 244
SO, as you can see, the mobo is a tad larger than the case allows. BUt seeing that the amount is very minimal, does anyone think it could work? I thought my search for a case was over and i was going to head out tomorrow to pick it up but this may change things.
Case 304.8 x 243.8
Mobo 305 x 244
