I recall reading about a bunch of problems with the Dell's (P991). Dunno if this would be applicable to yours, but you might want to check out their help site. Anyways, from what I was able to read on the 'net, a certain amount of "curve" is supposed to be deemed acceptable by the manufacturer. I'm not sure what the exact amount was, but I think it was something like a mm or so. The one I had actually had curves over the >entire< screen. If I displayed a hatch-mark over the entire screen, none of the rectangles would be the same size. Definitely sucked. I think it's ultimately up to you though. I mean, if you got it for a nice price (that 20% deal recently?) than if you can live with it, keep it. The problems I had were a lot worse than yours, so I RMA'ed mine.
btw, sucks that there aren't controls for the top/bottom part of the screen. Left/Right problems can be fixed, sort of, with the pincushion controls. There's probably some technical reason why they never include top/bottom controls.
