Help with Monitor output to TV
irenealan
382
Hi:
Just wonder is there anyone I can connect my graphic card to TV so I am view movies of my PC on TV. My graphic card has a standard output to the monitor, is there an adapter or cable I can buy so one side will hook up with the Monitor ouput of the graphic card and the other side hook up the RGB input of TV? Thanks for your help!
Irene
Peter
9,640
No RGB output suitable for TV sets from graphics cards. You get Composite or SVideo, and the midrange to high end ATi cards can be equipped with a Component adapter for HDTV.
