Help with Modem and IR base
Soapm
44
I am running 2K but recently decided to add a modem for sending faxes
only. The modem works great. I have always had a Motorola Timeport pager
that I could synchronize with my Outlook address book. This stopped
working when I installed the modem. I noticed the modem and charger base
are sharing the same COM Port but I do not know how to stop this.
My modem is listed as HCF 56K PCI modem and works fine. The pager is
listed as Motorola Deluxe Charger Base under Infrared Devices. I says it
is working fine (devise manager) but it no longer communicates with my
pager. I do not see how to change the COM Port for the Charger Base but
changing the com port for the modem is easy. Problem is where ever I
change the COM port of the modem to the charger base follows to the same
port. How can I force my charger base to its own COM Port?
