I am working on an Athlon XP 2.1Ghz that had a defective hard drive and I am testing all the other hardware components for good measure. I loaded MemTest86+ v1.55 from the UBCD to test the single 512MB DDR chip that is in the unit. It has been running for just over 2 hours and has found one error. The system is running a nVidia nForce2 chipset and the RAM specs are displayed as 166mhz, DDR332, CAS 2.5-3-3-7, single channel (64 bits). My question is how long should I let this program run for and is this one error permissible? I have run this program in the past and once it immediately came up with many errors so I simply replaced the DIMM and everything worked fine afterwards. Any other tips are greatly appreciated.
