- Jan 29, 2005
- 35
- 0
- 0
Hi I decided to have another go at playing with my memory and I got further this time than I did before.
According to the dividers in the BIOS the memory should be running at 210mhz but in CPU-Z it shows this.
Is there another program that I could use to check what speed my memory is actually running at or should I just believe what it says in the BIOS?
Also is there much or any performance increase from running at cas 1.5 and am I correct to believe that A64's get more of a performance increase from tighter timings than higher speed?
One last thing. My ram is ddr400 OCZ rev3. What would be the highest voltages that I should try?
Any help any of you can give would be greatly appreciated.
Opty 144 (9x300)
DFI Ultra-D
x1800xl
etc.
Opty 144 (9x300)
DFI Ultra-D
x1800xl
etc.
