Help with MD Deck and Optical in
marketsons1985
2,090
Ok, here's my problem...
I was using my MD deck, (Model number MDS-JE330) connected to my computer with regular analog cables (i.e. the ones that are red and white)
I just bought a new sound card, a Hercules Fortissimo II, and it has an optical out, that i can connect my MD deck to. So i did that, However, when i try to record on Digital mode, it gives me the message "Din Unlock" then flashes "C71"
I cannot find my manual, does anyone know what the heck's goin on? Help!
sohcrates
7,949
well, i'm not sure what that message means, but are you sure that your digital output is enabled? sometimes you have to turn that on via software before anything actually comes out of it
just an idea
marketsons1985
2,090
Yah, the output's workin, i enabled it on my comp.
Anybody else have any ideas what this could mean?
flood
4,213
Try running your sound from the digital out, thru the md's dac, and thru some speakers. This'll confirm that everything is hooked up right and working. then the problem would be localized to the MD deck.
Supradude
1,727
are you sure you have the MD set to digital in?... and make sure the ports arent dusty, excessive dust in the optical ports can cause weird errors...
flood
4,213
try changing the sampling rate to 44.1khz
i think the fortissimo defaults to 48 and your md deck may not support downsampling
GoSharks
3,057
Heres a link to the manual
the sampleling rate should not be a problem, i think all mdrs can downsample.
in the soundcard menu thing, the green one, on the other screen, make sure that the digital output configuration is set to be on "main outputs" and that copy protection is not checked.
