help with maxtor harddrives!!!
hKfoB
16
i just went to fryz and bought a 2 new maxtor 40 gb hard drive...rang for about 29.99 after rebates...one hard drive as an additional space on a previous computer and one for a new system...consisting of a celeron 700mhz, radeon 7500, and a regular sound blaster...(yea old parts)...well upon installing xp...i've been having trouble because right after the cd copies the files to the hard drive...the second part of installation keeps on restarting the computer by itself everytime...first i thought it was the hard drive problem so i went to download a utility from maxtor.com to check it out...i ran the test but it said that everything passed...the one im using as an additional drive works fine, but after a grueling partitioning process that forced me to split the drive by 20gb's and using FAT32 for it...maybe maxtor is crappy?...i don't know...can someone help me on why i can't install xp on the other one...plz thanks....
:confused::confused::confused:
amdskip
22,530
13
Maxtor isn't crappy. Paragraphs are a plus on this forum;)
You don't mention what memory you are using. Maybe you have a bad stick or not enough.
