Kyteland
I'm trying to do a problem from an IQ test somebody posted here earlier. The test can be found here: http://www.highiqsociety.org/common/iqtests/ultrahigh.htm
Linky to the problem
I can't figure out what the value for Y should be. The Y in the unsolved name is the only one in the problem. There is also no J, Q, or X anywhere in the problem.
As a shortcut , here is what I have solved so far.
A = 6
B = 11
C = 20
D = 24
E = 7
F = 16
G = 12
H = 5
I = 9
J = ???
K = 13
L = 21
M = 2
N = 22
O = 8
P = 14
Q = ???
R = 23
S = 15
T = 3 <---Edit: Typo, was 2, now is 3.
U = 10
V = 4
W = 17
X = ???
Y = ???
Z = 18
Each letter has a unique value. I'm assuming their range is 1-26. The unused values are 1, 19, 25, 26.
The solution will be this: FEYNMAN = 75+Y. Possible answers are 76, 94, 100, 101.
I tried to find a pattern in the numbering which would fill in the last 4 numbers but I couldn't find one.
My best guess is that the answer is 94 because there are only 23 letters used in the puzzle. If I assume that the number range is only 23 instead of 26, then that range must be 2-24 and the answer must be y=19.
Does this sound right or am I just reaching for an answer here?
A = 6
B = 11
C = 20
D = 24
E = 7
F = 16
G = 12
H = 5
I = 9
J = ???
K = 13
L = 21
M = 2
N = 22
O = 8
P = 14
Q = ???
R = 23
S = 15
U = 10
V = 4
W = 17
X = ???
Y = ???
Z = 18
