Help with Mandrake 10.0+ kernel 2.6 [SOLVED!]
EnDaRi
Ok, I don't know why but i keep getting installaiton errors:
libxfree86-4.3-30mdk.i586
libxml2-2.6.6-1mdk.i586
esound-o.2.32-3mdk.i586
so far are missing and there are errors
It also freezes during the installation of the first ISO cd of the 3.
I don't know why this is...
Comp specs are AMD 1000+
A7Pro Motherboard
2x256 mb SDRam PC133
ATI Radeon 7000
HP cd-rw
Maxtor 80 gb/5400 rpm
Its not the cd's, or the cd drive, cuz i tried 4 diff CD drives to finally get it to read. And the CD's, well there are like 4 burnt copies of one ISO...I doubt its the IDE Cable, cuz i tried 3...I've tried kernel 2.4 and 2.6
Please someone help me install Mandrake 10.0 !!!
I'm suspecting its the Hard Drive...that is corrupted, because i tried installing windows xp pro and it also had errors installing...
Or what about the cdrom?
If two OSes aren't working it suggests it's the hardware.
(Does mandrake have a disc-checking utility in the installation routine?)
not the cd drive. Because the first one i tried didnt read correctly, or so i believe. Second didnt work, third didnt read because it was out dated, and last read it perfectly... so its not the cd drive
I'd def try a new HDD. Mandrake 10 installed for like cake. 1 hour and it was all set up, on the network and dual booting with no problems.
because i decided to try to take out one ram stick and test only one of them out. And the first one i tried kept reading errors on bootup. The second one ran fine with no errors during installation. It now only freezes when I get near the end of installation...Gotta figure it out...unless any of u have any pointers...
