So, in Terminal (OS X 10.4), I can't enter my password. I can type in text and enter commands, but as soon as it prompts me for my admin password, i can't enter text anymore in Terminal. Help!
it seems to accept the password, but i cant get the command im using to work. I'm trying to change my MAC address, using this command: sudo ifconfig en0 ether theaddress
i dont get a confirmation message, but it accepts it- but its still the same when i check my address in system prefs, even after a restart. what am i doing wrong?
Give us the exact command template you're using, including the MAC, and perhaps we can see what is going wrong. Leave sudo out of it - connect as root with sudo -s before you do this command.
