Crucial Rendition 1GB PC2-5300 DDR2-667 240PIN DIMM Memory
ASUS M2A-VM mATX AM2 AMD 690G DDR2 PCI-E16 PCI-E1 2PCI Video VGA DVI Sound Motherboard
Corsair CMPSU-450VX 450W ATX 12V 33A 24PIN ATX Power Supply Active PFC 120MM Fan
AMD Athlon 64 X2 3800+ EE Dual Core Processor AM2 Windsor 2.0GHZ 512KBX2 65W 90NM Retail Box
Hi, these are the parts that i chose for a very low budget build. I want to spend as little as possible, im reusing my HardDrive and DVD drive. My question is is it worth spending an extra 10$ for the 2.2ghz AMD? Is there any parts that i should change? thanks
The uses of this computer is mostly for school work, and gaming if someone brings a video card over.
edit: the cost of this will be $247.95 CND from NCIX
