Help with Login Script
err
I would like to create a login script that would automatically do a registry hack on the end user's computer.
What is the line that I should pop into the login script ?
Thanks for the info
eRr
What kind of login script? NT/Win2k or Netware?
You most likely just need to run a .reg file from the script. I am not sure on how to do that in a NT script but on a Netware it is something like the following:
# regfile.reg
