Help with litestep and winamp
aolsuxs
687
I just installed Winamp3, yes I know I am a little late, anyways my geek amp for winamp does not work for it, instead it uses Winamp 2.78 or whatever I had before. I even uninstalled winamp2.78 and now nothing happens when I click the icons on the top of my screen where geek amp is, Here is a screen shot
sandorski
70,674
6,247
I can't really give you the answer, but you'll need to update one of the Litestep Modules(probably named something else). I have no idea if one even exists for Winamp 3, but you could probably find out at the Litestep website.
Bullhonkie
1,899
The Geekamp module doesn't work with Winamp3. Someone wrote a module that translated the geekamp calls to something Winamp3 can understand, but his page generates a 404 error now. So I'm not sure where you can get that at.
Your only choice may be to go with a module called DynAmp. It works pretty well from what I've heard, based off the Geekamp codebase and works with both Winamp 2 and 3.
If you want to try and track down the module that lets geekamp work with Winamp3, try asking at lokai.org or on the litestep.net forums.
