ok.. first of all, bear with me this is my first attempt to build a wireless network...
i got two computers to network and a printer.
both using the linksys pci wireless card (WMP11) and i got the linksys wireless cable/dsl router ap + printserver.
i installed the drivers for the wireless pci card and the router software comp on both comps.
the funny thing is on both computers the internet connection (from the cable) works fine. IE loads up websites on both computers (but it takes like 1min when I open IE to load the first site; the second, third, etc sites load normally)
[problem 1] following through with the router manual, i come to the point where it says load up IE and enter HTTP://<router ip> which I assume should be 192.168.1.1 (not 192.168.0), when i enter that it, it comes up with a username/password prompt. i enter in my @home info (this is the step which i have uncertainly), but it doesnt let me logon.
just out for curiousity i tried other ips like 192.168.1.2 and 192.168.1.0 and those dont do anything at all (no website detected blah blah)
[problem 2] i have a HP OfficeJet 700 series machine. i heard that most "all-in-one" multifunction machines dont work with routers, so maybe that issue to linked to this problem. but when tried to add a shared printer port to either comp, it wont add properly (im using the linksys router software). it detects Port 1 to be ON-line and it says the port was sucessfully added. but then when i go to the add printe rstep, it shows up no shared printer ports. i dont even think it detects the printer.
any help is much appreciated...
