Help with LAN problem!
AFurryReptile
Can you hook up multiple routers to perform like a switch, for example, hook one 6 port router into another 6 port, and hook up 11 computers?
yes, just disable the DHCP server on one of them.
You may need a crossover cable - just plug one lan port on a router to a lan port on the other. There might be a switch on your router labeled MDI/MDI-X - if so you don't need a crossover cable.
