HELP with kt7pro2a!
grifterspawn
1,007
I just picked up a MSI K7TPro2A for my second comp, with a duron that will do 600@1000 1.85v. So I go to try and flash the bios so I can use that extra voltage, nothing happens, the flash just stalls. I reboot and it works fine, but of course the overclockers bios wont work, so then I try LiveBios, well they dont have the bios with the extra voltage on it. I read in another thread that you can possibly disable this lovely feature with a jumper, but if so where? If anyone knows how to do this I really need your help.
Thanks
Ian
JimmyZ
125
pencil the L7 bridges just like you did the L1's. It will boot at a default voltage of 1.85 and you can turn it down from bios if you like. This way you can continue to use the offical MSI bios updates.
Jimmy
grifterspawn
1,007
Thanks, I may just have to do that, but I am curious why the thing just hangs instead of flashing, live bios works...but I dont trust it much, and I really want that beta overclockers bios. Anyone else have a clue what might be going on? (and yes I tried the usual flashing techniques, with bootable floppy, straight from hardrive, etc.. etc.. nothing works...) Any help would be appreciated.
Ian
JimmyZ
125
Ian,
I have heard nothing but bad things about the OC bios. I have the L7's penciled in on my Duron system and it works great. You gain nothing from the OC bios that you don't get from MSI's newest BIOS (4-way interleaving).
Some people swear by their OC bios, and I'm sure there is nothing wrong with it....but I just know what works for me.
Good Luck
Jimmy
