HELP with KT7A Raid Hour glass on mouse wont stop??
Mustanggt
3,278
I just upgraded from kt7 non raid to KT7A Raid thinking it would be worth it with the extra FSB performace plus the xtra Raid performance. Anyways I have been trying to figure this out with no luck everything works great with raid benchmarks at 33000 but I keep getting the hour glass on mouse every 3 seconds I dont know how to fix this?? tried disabling bunch of stuff no go someone know what to do Thanks
Mustanggt
3,278
thanks for help people so far I been working on this for most of the day and unpluging my plexter has solved the trouble. only thing is now figuring out how to run my plexter on IDE1 while running Raid? the plexter and my cd drive wont run together on IDE2 for some reason.
Pederv
1,903
Check your post when you re-boot see if your plextor is being recognized as PIO Mode 4 or UDMA 33(you've gotta be fast to do this). A buddy of mine's plextor is showing up as PIO Mode 4 and when he installs liveware 3.0 for his SB Live value his plextor disappears(when the plextor is set for DMA in hardware manager). He can use Liveware 2.0 and not have the disappearing problem.
I've seen so many different degrees of flakyness when you have a bios recognizing an ide device as PIO Mode 4 but the user enables DMA in windows.
