Help with K6 Fan question
Tomahawk
Really simple question is what i got. Answer you must!!!
Sorry, just watched SW:ESB for the 100th time.
Anyways, What kind of cpu fan is on a k6-2 400 mhz.(Actually, i can't remember if it was k6-2 or k63).Looks like a 486 fan, but i wanted to make sure. My friend says his is dead and i need to get him a new cpu fan. And where can i get one relatively cheap. Thanks!!!
all you have to do is find a fan which is the same size(it'll either be 40, 50, or 60mm) it doesn't matter if the fan is marked as a '486' or 'pentium' fan, they're all the same so long as you get the same size(within reason, some fans have more output than others of course)
