Help With ISO File
Agaruvala
218
Hi guys, I need help.
I'm building a new rig and need a OS, so my brother gets an ISO file with with a VALID key.
Can I burn that ISO file of XP pro ona cd and use it as a install disk.
Its being installed to a new drive
MrChad
13,507
How about you buy your OS? Piracy discussions aren't allowed here.
Agaruvala
218
Kick back turbo, I said VALID KEY, I no OS burning mofo. cool your jets
I bought it through the microsoft academic alliance.
MrChad
13,507
Ok, well valid key does not always mean legal key.
So it the ISO file from Microsoft Academic Alliance? Or from some other source?
Agaruvala
218
Agaruvala
218
Can't I just burn the ISO file to a CD and use it as a install disk, OR no.
IF yes then do i need to burn it using a special program or method ?
THank you for your time.
PS: I like microsoft I do not make illegal coppies of their stuff
Agaruvala
218
Chad you need to stop the hacker crap.
Anyway, I talked to microsoft they said that it should work fine BUT.
Because its a ISO file it will not be a bootable a disk and that i need to make a book Disk (floppy) or insert a retail cd boot off that, then when it gets to the first part of windows setup, switch the disk from the retail to the ISO.
Chad, I pay for my software, not ever one is a thief. lay off
MrChad
13,507
I'm not accusing you of being a thief. You say you have a valid, legal key and I believe you. An install CD can come from anywhere, however. You could download an XP ISO off of BitTorrent and use a legal key and you would have a legal install of Windows.
Some of these install CD images are not bootable, but most (all?) the CD and CD images that Microsoft provides are bootable images, so it should work just fine.
Shamrock
1,441
567
you can download Nero trial, and there is a section about bootable CD's. if you check that, you should be able to boot from it, as well as use it as an install disk
ofiraltarasy
910
i will help you with nero there is a simple function of Burn image to Disk i did the same thing so i know what your going through just burn the image to disk and boot from it, it should work and by the way .ISO is an image file so you'll always need to burn them to disk unless its a game if its a game just get alcohol 120% and that will make a virtual drive for youso you can do it like that but thats only for games and applications
daniel49
4,814
hope you had better luck with nero trial then I did. I downloaded it, installed it, then started it up, and it said my free trial was over.
Agaruvala
218
ok download nero, will let you know what happens .
The ISO file is in a zip file do i unzip it into a folder and then burn or burn it in the zip, if i unzip it to a file what do i call it
Nevermid it just looks like a zip but it says .iso
GhettoFob
6,800
That happened to me too. 😕
