cKGunslinger
This is probably a basic question, but networking always seems to confuse me at some point:
Current situation:
Adding New Hardware:
The Good, Bad, and Ugly
I can see all devices and log into the IPCOP Admin Webserver from any browser on the GREEN network.
Internet works great on my static-IP devices, provided I set the Gateway and DNS server to the IPCop IP address (instead of the Router's.)
DHCP devices assigned by my Router do NOT have internet access.
Ideal Situation
What I'd like is for the IPCop Firewall to be transparent to machines on the other side of the Router. I'd like my Router to appear to be the DHCP server, DNS server and Gateway for all my devices, while my Router gets all its info from IPCop. The only direct interaction I want with IPCop is through the webserver.
As it stands, if I decide to move IPCop online/offline and plug/unplug my internet PPOE directly into my router, I have to edit all the network devices to change their settings. I'd like this to be completely transparent to all network devices, but I'm not quite sure how to go about this.
Current situation:
- Internet comes in through PPOE device into the WAN port of my Router
- Some devices attached to the Router are static-IP (my PC, network printer, etc.)
- Some devices attached are DHCP-assigned IP (iPod, laptop)
- Older PC running IPCop (firewall/filter) in between PPPOE and Router
- IPCop (RED) logs in through PPPOE and gets an IP from my ISP.
- IPCop (GREEN) plugs into a standard port into the Router and appears as just another device.
Ideal Situation
