- Mar 11, 2000
- 6
- 0
- 0
System:
AMD Athlon 600 (Slot-A).. bought in March 2000- 1st generation?
In-Win Q500 Full size tower case.
Giga-byte GA-7ix Mobo
256meg PC-133 SDRAM
30GIG maxtor 7200rpm drive
Hitachi GD-500 8x DVD Drive
Plextor 8/4/32 CDRW
Creative Labs Annihilator PRO 32meg DDR
SBlive Platinum
Linksys Ethernet card
250watt generic power supply
Win2k OS
I recently purchased a new Enermax EG-465 (with mobo fan control) and need some input on installing this unit as the fan is controlled by the mobo and my old PSU didn't have this so I need to know how to hook this up.
Currently my AMD Athlon has two fans on it. One of the power connectors to one of the fans is connected to the 'Power Fan' connection on the mobo and the other fan is connected to the 'CPU Fan' connection. However the Enermax Manual said to use the 'Power Fan' connector. If i do this, then one of my fans on my Athlon won't work. Can I hook the power connectors to the CPU Fans to a regular power connector off the power supply and not the mobo? If i do this, i believe the fans on my CPU will consistantly run, but my PSU will be able to adjust it's fan speed as heat builds up.
here is a link to my mobo manufacturer and it's model: GA-7ix
http://www.giga-byte.com/support/support.htm
If this doesn't make sense (which i'm sure it doesn't, please respond and i'll try to make it a little more clear).
256meg PC-133 SDRAM
Plextor 8/4/32 CDRW
SBlive Platinum
Win2k OS
