helping a friend install wireless network in his house.  the house is not -very- big but is very expensive...  so i guess there is some tough stuff in the walls.  the configuration of the house (and expensive wall/ceiling material factors such as extensive wood paneling), make a hard-wire solution highly impractical
installed a netgear fwag114 wireless router that does a, b, and g wireless in the upstairs 'attic' room (like floor 2.5). the cable modem is there so assume it is the only place to install it.
friend wants to be able to use laptop, wirelessly, and have a printer on the network in the farthest room from the 'attic', the den. which is on the first floor, but still only about 35m away in a straight line, and in the basement, which is almost directly below the attic.
using a netgear b/g pc card for laptop, i am not getting adequate signal in either location
i tried purchasing a D-link 'range extender' (i was told D-link was the only ones who made such a device) - functioning in repeater mode, and placed it halfway between the target areas. the netgear pc card is able to see the signal as a second transmission source and gets 100% signal strength in the den and is able to connect, briefly, and get an IP address. but i havent been able to surf the net, and the netgear card loses connection and restablishes connection regularly in a repeating cycle - 1 min on/1 min off. i believe some combination of netgear and dlink is not working well together...
i need suggestions and options at this point.
i have thought of getting an 11a card for the latop. as i remember, 11a has longer range (and operates on a higher frequency), so is more likely to work fine at that range. problem: also need that wireless printserver in that room. chances of finding a wireless 11a USB printserver at a reasonable cost? yea thats why i chose to go with b/g
i need an access point that can bridge itself to the router wirelessly :/
~Zippy!
~Zippy!
 Facebook
Facebook Twitter
Twitter
