<originally posted in tech-support... maybe better luck here...>
I use IE 6 on win xp pro -- and occasionally "view source" doesn't do anything.
Normally it shows me the source in notepad -- but sometimes it does _nothing_ -- nothing at all -- and I can't view the source.
I'll delete temp files, cookies, close/re-open IE -- and then it'll work again (but i don't really know that that has anything to do with it working again)
any ideas?
I've scanned with spybot s&d and housecall, just for the heck of it -- and nothing -- so I'm leaning toward an issue with IE or winxp-pro.
Logged in as restricted user... which should make no difference.
any ideas?
