I'm planning to configure an IDE RAID system, i've been reading the manual, but still i'm not sure what to do. My disk are: two (2) 20GB MAXTOR IDE 5400rpm, one (1) WD IDE 80 GB 7200rpm with 8MB buffer half partitioned.
I want to configure an RAID 0 system for performance, but i'm not sure how to setup the disks, it's my first RAID attempt.
My mobo has the basic 2 IDE's, and additionaly has an IDE3 for PATA RAID by promise PDC20579, i wil not bee using any SATA disk.
So, i plan to set up the 2 Maxtor 20GB disk in IDE3 RAID 0, and leave the WD 80 GB Master on IDE 1, but i'm not sure this can be done and i have several doubts:
1.- Is this posible to do?, can normal IDE disk work together combined with RAID disks?.
2.- Wich disk will be my boot disk IDE or RAID?, i wish to install windows on the 80 GB disk, and leave the RAID for page file and games installed, is this a good choice for better performance?
3.- Is there a better performance config i can do?
4.- Do you recomend NTFS, FAT32, or mixed, wich is better for performance?
5.- By the way, I usually wish to have 2 Windows XP PRO SP2 instaled, 1 only for gaming in order to get the better performance (no office instaled, no antivirus, no firewall and unnedded services turned off), and 1 for general usage (office, antivirus, firewall, lots of programs and services fully enabled), both instaled in the 80 gb disk 2 partitions.
well, i'll wait any comments and recomendations.
