okay so i am trying to add a new hard drive to my computer and i am having some problems.
okay so here is my set up:
primary cable: master: 60gb hard drive
slave: lite on cdrw drive
secondary cable: master: none????
slave: generic 56x read cd drive
okay so here is my problem i have been messing around and grabbing some of my old HDs and when i plug them into the master slot of the second cable nothing seems to work.....
i have tried the different cables and different setups and i can never seem to get my secondary master to work....
also i can't seem to get both the cdrw and cdrom drives onto the same cable...... when i do that neither is recognized... can you only have one cd type drive per cable? that doesn't make sense to me....
i have tried making my primary cable to have both HDs and the secondary to have both cd drives and it doesn't work....
are there some rules to IDE cables that i am missing?
i can just use the new HD however i really dont feel like transfering everything and i like the extra space... another option is an external USB HD however they are more expensive.
