I need to build or buy a new PC. My old PC which I built in 2005 and kept updating is dead (boots for few seconds and shut off). Don't laugh but I was able to keep it running 24/7 because it was a Supermicro Dual Xeon (3.0 GHz), ECC memory, and kept upgrading the powewr supply, memory, graphics board, SSD, operating system, 15K RPM SCSI Cheetah drives (RAID) etc.
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Used for general computing, Adobe Photoshop, Adobe Premier (basically transfering old family movies to DVD), Encore, InDesign, Desktop publishing, accessing medical imaging and charts from home. No gaming.
I want speed, quality, upgradability, workstation type stability.
I am entertaining runnig a virtual machine for older programs and laser printers (XP)
Want to use PC to store and play high resolution digital music (hook it to high end stereo system)
Like computer to be on the quite side
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$5,000 +/- for computer alone
3. What country YOU will be buying YOUR parts from.
USA
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU.
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
Presfer Intel, nVidia, Asus, Supermicro, had good luck and bad with Seagate drives.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Not realy, maybe a plextor optical drive
7. IF YOU plan on overclocking or run the system at default speeds.
Depends, if I go with i-7 then yes, if Xeon, then maybe not as they are not meant for overclocking
8. What resolution, not monitor size, will you be using?
Eventually a 4K monitor. Now, whatever a high resolution video board will do.
9. WHEN do you plan to build it?
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it.
Anytime now.
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
Windows 8.1 Pro. Nero ro CyberLink, and update older software
I'm looking at Haswell-E i-7 5960X or equivalent Xeon v3.
Motherboards ASUS X99 E-WS, or Dual Xeon, or equivalent Supermicro board. Start with one xeon (if this is the route) and add another later. Start with one graphic card and add another SLI one later?
The case should have front access to at least 3 5.25 drives.
My big dilema if I need a dual xeon motherboard these days when there are 6 core multithreaded i-7.
Any input is appreciated. Thanks
USA
Anytime now.
