- Jan 10, 2010
- 1,238
- 2
- 76
I have a Sony LCD rear projection TV (720P) that does not have HDMI-in but does have a DVI-in. The DVI-in works great with my laptop's HDMI-out using an HDMI-to-DVI adapter. My question is, how likely is that it will also work with a Bluray player using the same HDMI to (DVI+adaptor)?
The TV is HD compliant or whatever that acronym is, that's what displayed by my mobile-Nvidia laptop. I'm aware that I won't get the full 1080P picture (because of my TV resolution) even if it works and that's fine with me because if it looks anything like the HDTV programs that this old TV can display through its component input from the cable box then I'm more than satisfied.
I just want to make sure that it will work before buying a bluray player. This is an older TV in my man cave.
